question.... is the safc1 and 2 that different from each other? Is there any particular advantage of getting one over the other?
Prettyazznouka;927625 said:so the safc2 would be a better buy? Or what about the NEO?
Jostar;892691 said:The knock detection on my AEM, i believe is disconnected, Sound performance didn't really need it, Alot of high horse power tuners don't need it.
bigaaron;927933 said:Exactly, if you have to rely on knock dectection for a safe tune, then something is wrong with the tune or the engine/fuel setup.
bigaaron;928124 said:I have a knock sensor, actually I have two...... MY EARS!
Knock sensing is retroactive. If it detects knocking, it's because it's already knocking.
tissimo;892530 said:I guess if you're not going to use the features then yea, its pointless to spend the extra money even though the features are quiet useful. But then why not just get megasquirt which is 1/2 the cost of Stinger and does eveything you and the vast majority of SM members need.
rakkasan;890615 said:No more worry of stock ECU failure, TOTAL control of your motor. Emanage is a glorified (but good) AFC. I ran one for a while, and was happy with it, but stand alone is rather cool. It takes a while (or it did for me) to work out some bugs, but there is definitely more power to be had. I'm still working on my cold starts, but all in all, it's worth it....
jza71;927865 said:Apexi Power-FC
Plug in and drive away, stock map already loaded on.
Krister;930894 said:Can Emanage raise the rev limiter and adjust the timing?
