ive got my innovate lc-1 hooked up to send as emulated signal to the stock ecu to keep it happy. its working fine. the only thing i havent done is get rid of the check engine lite (code 21) for no sensed resistance on the heater wires. tsrm says spec is 3.0 to 3.6 ohms.
if i take a 1/2 watt 3.3 ohm resistor and use it across those wires, will anything burn up? im not sure 100%, but by my calculations (ohm's law) it would be around 4-5 amps with 14.5 volts and 3.3 ohms resistance. is that how much current the stock o2 sensor's heater pulls?
edit: holy hell, i pushed an extra button. the amperage would be 4 to 5 amps... lol
