EMB Throwing Code 26? Help!
7mMoneyPit
30
Baltimore
Hey everyone, I recently bought a Greddy Emanage Blue unit and wired it in. Now when I start my car the red light starts to flash after a second or two. I turn it off and back on to display the codes and I keep getting code 26 which is no injector 6 pulse, I have rewired it 4 times and still getting the same thing, any ideas on why? Thanks for your help!
btw I went by this diagram : http://www.greddy.com/img/PHP/products/pdf/1246.pdf
7mMoneyPit
30
Baltimore
Ok on the code 26, I found that the PO of the emanage had swapped wires on the harness so all I had to do was wire it up accordingly. Now I'm having a problem with the emanage running the afm signal. Input at idle says about 24 output is usually 0 from emanage, when I hit the gas it bogs down and if I don't give it enough gas it will stall. I've tried messing with engine anti stall feature but anything more than a value of 10 causes instant stall, any adjustments to afm map don't seem to do much for me on this, Any ideas?
7mMoneyPit
30
Baltimore
Any Help???
I am also getting confusing info on the rotary switches on the emanage.
I'm running a 7mgte and haven't hooked up the Ign harness yet just Injector and main harnesses. As far as I can tell I should be using 6 8 4 as settings but not sure as I've seen some people run on 5 8 4 once the Ign harness is connected. Please help me I'm so close to finishing!:1zhelp:
Ok I've been to http://www3.sympatico.ca/zazzn/ and according to his diagrams I should be running 6 8 4 until I add the Ign harness then I should drop it to 5 8 4 I was wondering why and if it has anything to do with my idle and bog issue.
