emanage
Justin
Speakers?
Spokane, Wa
on the diagram I have of the way to hook up the ignition harness, with the 1kohm resistor and the transistor, everything eems to be a bit jumbled.
I've got the ground going to the collector of the transistor,
the IGf going to the emitter, and capped off on the ignitor side
What does the IGt wire go to? I've got the base of the transistor free, also the 'IN' of the emanage to go to. and the RPM to splice in (I can figure tha out)
answer me that and i'll make a much more clear diagram
encomiast
boosted kraut
germany
I guess you are referring to this diagram?
as I see it, the IGt signal coming from the ECU is connected to both the RPM input and the CH1 input of the emanage, as well as to the base of the transistor.
I think the problem with the diagram is that the transistor has been added afterwards, so it lacks a bit of clarity.
