emanage ultimate on 7mgte! help with that!
madtico
need a chevy!
Apr 11, 2007
21
miami
i bought an emanage ultimate for my 7mgte supra, but i am not sure if it could work! help with that!
loki2043
645
Portland, OR
have fun figuring it out. from what ive heard nobody has really taken the time to get it to fully work with the 7m. except some guy on an island somewhere..
bowsercake
828
Irvine, Ca
Uh, it's not that hard. The EMU will hook right up to the 7M but you need to use a different car with the KV afm and 6 cylinders. I think it might be the Dodge/Mitsubishi 3000GT that uses this setup.
From there you load it up in your laptop and begin to tune.
The only thing that people are having problems with is setting up speed density because there is no base map. However, the Emanage Ultimate will work fine. I don't know why people keep saying that it wont, I bet they don't have one.
It mostly works, it will just take a lot of time and work with the map to get the speed density mode to work.
YoNkErS87t
streetside mechanic
In the Garage
The old Emange worked on the 7m so the ultimate definitely will.
Like Bowsercake said there isnt a base map for the 7m, you have to work off a different car
madtico
need a chevy!
Apr 11, 2007
21
miami
could i take off the afm and use the greddy map sensor? that way i could use the 1j as the base map?
bowsercake
828
Irvine, Ca
The Ultimate is still a piggy back so it will use to stock map and then you make adjustments there. There are only problems when you try to run it without the AFM.
