I decided to upgrade the wiring and see how it helped but I also wanted to get my alternator checked out. After getting it tested it showed good so I went to reinstall but when I put my wires back in my the metal from the connector that I had on the alternator positive to the battery was touching the case of the voltage regulator and I hadn't noticed at first and when I hooked my battery back up I blew the 100amp alternator fuse!! After replacing the fuse and readjusting my wiring I was able to get the car to start but now I have new problems.
1. My greddy fatt ii no longer functions properly. As soon as I turn the car off it turns off.
2. The voltage that my turbo timer reads is 1v higher than what my safcii reads and I'm not sure which one is right. I assume the TT as the Safc reading is low most of the time yet i don't have the same cutting out problem.
3. This is the worse part. It is now difficult to get my car to stay on when starting. It will turn on but unless I apply a little throttle it will cut out. I also have to constantly apply throttle for a few minutes while driving. After it warms up some then it's ok. I checked the resistances on the cold start injector and the time switch and the appear to be in spec but I'm not sure if it is functioning properly as my car used to idle at 1k before it warmed up
