EFI fuse keeps blowing
Apr 4, 2005
55
Milwaukee
This is on my buddies car. Everytime he launches the EFI fuse will blow. He even put a 20 amp in instead of the 15 amp, and it still blew. He just installed a MBC but has the boost set down at 7.5psi and it is still blowing the fuse. What is wrong with the car?
empera
Authorized Vendor
Philly.
i had this problem, how did i fix it? i dont know!....well i unplugged certain things and kept tryin it on the on position...tried the O2 sensor, seemed to be fixed but then i plugged it back it and it didnt blow? dunno wtf...
macsupra76
128
Calgary AB
I had the same prob, but it was during rush hour doing 150km/h on the highway and the car just died, really scary.
Anyways the problem can be from many things:
Shorted grounds
old wires
modified wiring
dirty connectors ....etc.....
mine was a damaged ground cable(negative) coming of the battery. Good LUCK
