Effing stuttering
casper35404
165
Tuscaloosa, AL
I have recently developed a problem with my car stuttering. It started one morning when I was driving to work and, with light acceleration, my car felt like it hit a quick fuel cut as soon as I heard my turbo start spooling (T04E). When I got off of work it wasn't doing it anymore. Now it's messing up big time. When I'm idling I'm running super rich and almost stalling out. When I'm lightly acceleration my car will stutter at about 2700-3000 RPM or when I make light adjustments to the throttle. Everything seems to be running fine when I go WOT or heavy acceleration. I am throwing a code 31 which I know is an AFM code. I'm running the Lexus AFM. I've tried three different AFM electronics but all with the same problems (slightly worse with one of the AFMs). I'm taking it to the shop Friday to see if they can figure out what's wrong with it, I would just like to get some info from the knowledgable people on the forum to be somewhat prepared for bad news. Thank you to anybody who can give any feedback to my dear Supra's woes.
super.secret.supra.club
1,304
San Diego, CA
its gotta be your afm. i was messing around with mine a couple mmonths back and i forgot to plug the afm back in and around 2500 rpm the car would stutter really bad. i plug the damn thing back in and the car worked fine again. gL
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
I doubt a mechanic is going to be very helpful unless they've got some experience with the MKIII. Most will beat around the bush and tell you it's something else that's wrong (a lot of them point there finger at the ECU, dumb asses) and you need to replace said culprit with a new one. The next thing you know your pockets are much lighter and you still have the same problem.
casper35404
165
Tuscaloosa, AL
My mechanics have at least 12 years service at the local Toyota dealership, one of them owns a MKIII, and anybody in town that has a MKIII in town that takes their car to a mechanic takes it to them. So my mind's at ease on that subject. Could it be that all 3 of the electronics that I have tried were bad?
casper35404
165
Tuscaloosa, AL
Just got back from the shop. It's something that nobody expected. Bad rings. My car isn't even burning oil, but the compression test only got 75psi. Thanks to anybody who tried guessing.
jetjock
creepy-ass cracka
9,439
Supraboy89 said:
boost leak . or your turbo inlet has a leak
Wtf? That's bad advice if I ever saw some, in several ways.
Casper: While I won't dispute your compression test I will say it's not possible for bad rings to cause a code 31. A code 31 will however cause the problem you're having. I'd be getting a second opinion if I were you.
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
It could be something other then rings causing low compression.
The best way to tell if its the rings or not is to squirt some oil in the cylinder and do the compression test again, if it improves then its rings if it doesn't then you have either a BHG or something wrong with the valves.
casper35404
165
Tuscaloosa, AL
I'm not worried about it. I'm going 1J in August or September. I've been planning the swap for several months now. It honestly could be any of the above. I do drive my car pretty hard.
