ECUMaster DET3 Piggyback Video, NA-T 2JZ on 7M Electronics, AFM removed
Zach
ECUMaster USA
Apr 6, 2005
375
TX
We'll have an install and tuning video done shortly, and in much higher quality video, but here's a quick clip of an NA-T 2JZ running on 7M electronics. The AFM signal has been replaced by an output from the DET3 piggyback, the conversion to speed density is quite straightforward. No more stalling due to vented blowoff valve, plus it does ignition and fuel control, launch control, map switching, analog inputs, programmable outputs, electronic boost control, etc.
https://www.facebook.com/photo.php?v=1477616649162403
More information at www.ecumasterusa.com or here: https://www.facebook.com/ECUMasterUSA
empera
Authorized Vendor
Philly.
are there any harness adapters being offered for the early 7mgte engine harness?
Piratetip
Far From Maddening Crowds
1,179
70
MKE, WI
I can make a patch harness for the pre 89'.
