The wires to my ECU water temp sensor plug have snapped off from the plug. I have an old hacked up wiring harness, but the ECU water temp plug was missing on it. I found another 2 prong plug that I modified (broke the clip part of it off) to fit on the sensor. It actually worked out pretty well.
Now my problem is trying to figure out which wire needs to go to which prong.
According to the TSRM, the sensor is just a resistor: http://www.cygnusx1.net/supra/library/TSRM/mk3/manual.aspx?Section=FI&P=113
Does that mean that it really doesn't matter which way I connect the wires since it is basically a loop with a variable resistor in it?
Thanks for the help.
