I have 92 Turbo Automatic. I did a 5 speed swap and everything worked fine. Well i was drivin n the car shut off. I found out the ecu FRIED!!!! i traced the brunt connection to a pink wire. i found the pink wire on the erg unpluged and resting near support bar so im guessing it hit metal n grounded out fryin ecu. so now i need a ecu. so would any gray plug ecu work or do i need a 91-92 ecu?????? since i did the 5 speed swap can i use a 5speed ecu or does it need to be auto???
