ECU power wire short?
gotsomegetsome
Age Quod Agis
Mar 31, 2008
210
san jose
hey guys, so the other day i was trying to install a new gauge I bought
when I was messing with the wires, I dropped one on the other by accident and now I dont have any power to the ecu...or so i think
I have an safc2 hooked up, and that will not turn on.
this is why i think its the ecu power wire that has shorted out
I checked the fuses and all are fine, but im worried about the efi main relay
do you think i blew the efi relay? or is it just the wires....
any suggestions? haha besides to not short out wires
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
have you checked the main fuse bus (or whatever its called) in the fuse box under the hood? its the bigger blue fuse looking thing. ive popped that one before and it took me a while to figure out that it blew...
gotsomegetsome
Age Quod Agis
Mar 31, 2008
210
san jose
no i checked that completely
every single fuse in there is fine
which is why im confused
ive narrowed it down to this, the negative ground wires that run to the ecu are fine but the positive is not receiving any power, so it much be between the 10 amp ecu fuse and where i have the wire cut
has anything like this happened before??
gotsomegetsome
Age Quod Agis
Mar 31, 2008
210
san jose
yes that is what happens
to start the engine i have to run a power wire from the positive battery connection to the ecu directly
do you think it may be another fuse?
gotsomegetsome
Age Quod Agis
Mar 31, 2008
210
san jose
I didn't understand, you do or don't have the CIL with key on, engine off?[/QUOTE]
CEL? no check engine light, no power to ECU.
3p141592654;1269574 said:
Do you own a multimeter and know how to use it?
are you refering to continuity? .... it's pretty strait forward. No continuity = no power transfer through wire = ecu and thus ignition does not turn car on, not crank, but not even on. aside from the accessories, nothing turns on
so back to anything relevant to my question, are there any fuses or potentially weak parts in the wiring that I can pinpoint that arent located in the fuse box, unless the efi main relay is blown?
8,900
You can't run a continuity test through a power wire.
And if you unplug everything, you can drop 12.5 volts, yet show zero ohms on the continuity test. Not to be confused with the reading O_L.
Have you looked in the EWD yet? It shows pin out voltages with the key on and off, at all spots. Then you will see when you are to get power to the ECU.
Yes, there are several fuses that need to be checked electrically.
