Ecu Fried
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
ECU/s are notoriously sensitive to any kind of bad or misplced current. Has your car given or been given a jump start lately? One of the most common ways to short one out is by jump starting your car and connecting the negetive cables to negative on both batteries rather then have the jumper cable grounded to the frame on one of the cars Not to mention the effect jump starting your car with cables and another running car has on the voltage. Good luck
macsupra76
128
Calgary AB
The car will not turn over, it cranks but does not turn over.
After trying to jump start it I had to replace the 100 amp fuse for the alt, efi fuse, ign fuse, they all blew for some reason, and yes it was jump started after a winter of not being turned over the week before, and it ran. I checked all the realys, and the fuel pump, cold start.All i have to check is the ecu and ign sprk.
