E-manage with Split Second PSCI-005
Bishop92t
773
USA
www.ma70.com
It won't work with the 7mgte ECU. All it's doing is modifying typical 5v signals - MAP, MAFT, or flapper door. Won't work on KV AFM which uses a frequency. It would probably work on the 7mge but it wouldn't accomplish anything the e-Manage alone couldn't do (useful).
Bishop92t
773
USA
www.ma70.com
Highly possible. Unfortunately I haven't done enough work with AFM's other then stock Toyota & VPC to know the answer. IMO the MAFT would be the way to go for an N/A car.
DEFIANT 7M
101MM stroke of INSANITY!
Nashville/Miami
I've already purchased a 85mm meter from C&L and have the elctronics for 42lbs injectors. I've held off getting the Split Second looking for more feedback on it. But that has not been so forth coming.
