Dyno'd my car today
OneJoeZee
Retired Post Whore
aboard the Argama
Got a chance to dyno my car today at Bisimoto Engineering.
This was done on a Dynapack dyno.
I'm pretty happy with the numbers. Mods are 3in turbo back, intake, Mine's ECU, no boost controller.
btw, it says flywheel but it's actual wheel hp so don't get confused.
OneJoeZee
Retired Post Whore
aboard the Argama
I was looking at the stock 1J ratings and a bone stock 1J is listed to make peak power at 6200 and peak torque at 4800. My car made peak power earlier and peak torque later by a few hundred RPM. I would have expected them to move in the same direction instead of one going one way and the other the other way...
Just an observation:dunno:
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
Good numbers, one problem though, SAE correction is not soppost to be used on forced induction engines and so the true numbers are a bit lower then that.
8,900
Yep, good state of tune. Factory 7M's run close to 10:1 under boost. Your ECU leaned it out near 11.5:1, for a nice gain.
The increased heat decreases the spool time also.
OneJoeZee
Retired Post Whore
aboard the Argama
honestabe said:
If you get a 3" free flowing exhaust like me, you'll boost about 13-14 PSI and the 1J will love you for it.
um, I think you missed the part where I said I have full 3 inch exhaust already.
you're hitting higher boost because your wastegates are getting tired.
On a cool night, my car will spike up to 13-15 too.
honestabe
Happy as hell :D
Jan 15, 2006
3,713
Mount Vernon, WA, USA
Do you have a cat? I don't. Also, thanks for the tip on the wastegates, that's 2 more things for me to buy. Damn!
Disced
Pie + NYQuil = FTW
Edmonds, Wa
dude... you may rev to 7... but you lose power at like 5300... WTF?!
Also... Your a/f ratio at peak HP is like 12.2... Isn't that a little on the lean side?!?!
tissimo
Stock is boring :(
Melbourne, FL
torque starts falling off at 5300, power doesn't fall off till ~ 6300-6400 rpm..
12.2 isn't bad, it is a little lean for my liking, but for the low hp, shouldn't have a problem..
