bigaaron said:Here was my 50 trim:
Highest number was at 20psi, lowest was at 14psi. Had a exhaust leak at the manifold![]()
550's, maft was draw through, elbow and exhaust, forged pistons, spearco style ic, pump gas.
You really don't have to go 60-1 or bigger to make good power, the torque was almost 400ft/lbs at 3700rpm.
Snotcycle said:Also, it would seems that a 50trim would cause an efficiency fall off after 20psi
Snotcycle said:max horsepower at 3200? something looks wrong with that dyno sheet.
