Dual Walbros?
jz*supra
164
Lethbridge, Alberta
I think the mk4 has a triple walbro pump hanger you can buy. You would need to greatly increase the whole in the gas tank to make it fit, even two walbros require a little work to slip them in.
S
SLOW7M
Guest
Im trying to do a tripple pump set up on my car
Do you know where you can get the tripple pump hanger for the mk4?
gilberjj
Friend of Fast
Apr 14, 2006
661
Tacoma, WA
i know wotm.com makes them, and i think sound performance and titan make them too. they are kinda spendy in my opinion though. here is wotms hanger.
http://wotm.com/93sucncfuha3.html
these are proven, but when i come to that bridge, i think ill go with an inline walbro and i already have a walbro intank that will be feeding it
gilberjj
Friend of Fast
Apr 14, 2006
661
Tacoma, WA
annoyingrob said:
If you need 3 walbros, maybe you should think about getting some higher quality/flow pumps instead :)
ryan woon ran triple walbros for a long time. pretty much the whole mkiv community runs walbros. if ryan woon trusts walbros with his set-up, i will too!
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
they run 3 walbros because 3 stock pumps wont fit into the stock fuel tank. if they could fit the 3 stock pumps, theyd probably use those.
twin walbros have been proven to run out around the 900rwhp mark. the higher the fuel pressure, the more these pumps run out of volume. also when being asked to run higher fuel pressures, these pumps are stressed very much and will fail rather quickly. however, on the upshot, walbros are more efficient when it comes to power consumption. a fine stranded 14awg power wire and ground is adequate for a walbro. but asking a stock TT pump to push 500rwhp is going to take a little more than that. a single TT pump needs 30+ amps to operate under boost safely. which means, you cant just pick any aftermarket relay and wire install stock TT pumps.
btw, stock 14awg fuel pump wiring is far better than the equivalently sized aftermarket wire unless you specifically find high quality fine stranded wire. for instance, your typical "primary" wire from your local parts store only has about 23-27 strands in a 14awg cross section. however, the STOCK mkiv and mk3 14awg power and ground wires have 43-47 strands of wire... im sure i dont need to tell you how much better this stock wiring is compared to run-of-the-mill wire!
S
SLOW7M
Guest
The thing is i dont wanna run an external with a sump unless all other options fail
Justin727
T-virus infected
a few guys have not used the sump and tapped the bottom of the tank.
I was wondering if we do go external because I'm debating the samething myself. Can we just weld an AN fitting on the top of the tank fuel hanger assembly let it run to the bottom of the tank?
more input would be greatly appreciated.
dbsupra90
toonar
indiucky
i know of 3, me being one of those. it is tapped into the bottom of the tank inside the stock baffle. i wouldnt recommend just putting it anywhere on the tank. potential to starve the pump.
S
SLOW7M
Guest
Yea but if im gonna do an extrernal im gonna do it right and run my sumped tank
S
SLOW7M
Guest
First off im making a pump hanger i think i can weld in my own sump which i have done but i dont want to run an external pump if my tripple intak set up fail i will run my sumped tank with an aermotive elemniator but that is a last resort
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
you guys with bottom-feed pickups for your external pumps, do you use the stock fuel return line or what?
the only thing im afraid of is water collecting at the bottom of the tank if the car sits for an extended period of time. what would you do about that? turn the pump on and let it pump out any water, cycle it and hope it dumps back into the tank and breaks up before trying to crank the motor?
anyone installed a water/fuel separator from a diesel? my truck has one of these, maybe that would be useful for bottom-feed setups?
S
SLOW7M
Guest
What are you using for a fuel rail?
SMP142 said:
i am planning on running one aeromotive A1000 with -10 feed. using a sump setup of course.
dbsupra90
toonar
indiucky
ive never had a problem with water in my tank. but even if the car doesnt get driven, it still gets started regularly.
i have heard of people using sta-bil if they know its going to sit for a while. i dont have an personal experience w/ the stuff.
