Just getting my supra on the road for the first time. Im leaning towards MAF but Id like to know for sure. Heres the deal- It idles fine, light throttle is ok, but anything close to 0 psi and above the car gets a violent bucking going on. Power, not, literally like you were stabbing the gas over and over. In first gear its enough to chirp the tires. It blows no smoke during this, is on all the cylinders evenly, Ive flushed my whole fuel system so its not fuel flow. I show no engine codes. It had a code 31 as I was first getting the car running, I took the maf out sprayed it with maf cleaner and it went away. Pretty much everything is new on this engine so its not plugs wires ect. Ive done the ohm checks on the connectors of the maf, they looked okay, but I could be wrong the meter I was using wasnt ideal. Engine is an 88 7mgte, stock except turboback catless, intake, ect
