Hey guys, I am kinda chasign my tail trying figure out what is going wrong with my drive shaft situation.
First off, in the world of Cressida's doing a manual swap is a genuine bolt on occasion. It all bolts up just like it would in a MK3 (save widening the tunel for the R154). We use the MA70 bell/tranny/front shaft. N/A gets the W58 stuff and Turbo uses the R154 stuff.
Second, in the world of JZ powered Cressida's everything bolts up the same way, except the 1JZ R154 bellhousing is about an inch shorter resulting in other things being moved about 1inch further to the front of the car (when using the MA70 R154). The write ups for this JZ/R154 swap call for the JZA70 front shaft. Apparently, it is longer.
Third, I just bought a MA70 R154 front shaft because everyone keeps saying it is the same length as the JZA70 shaft. I have found that it is not long enough. It seems to be 1 inch too short.
My issue: I am being misinformed by either the Cressida write ups, everyone else, or the guy who sold me this drive shaft. I just want a straight answer so I can proceed in the right direct with my drive shaft issue.
So I got a few questions:
1 Are the JZA70 and MA70 front drive shafts the same length? . .. if think they are, please don't post up. If you know for fact cuz you've seen them side by side, please please post up.
2 If they are the same, what is the length of the MA70 front drive shaft? I'd like to verify whehter I am actually in possession of the correct shaft or not.
3 If they are different, what is the length of the MA70 front drive shaft? I'd like to verify whehter I am actually in possession of the correct shaft or not.
Thank you guys for your help
-Jago
-Jago
