So does drilling out the J-tube lower fuel pressure since it no longer restricts the fuel flow?
If that is so, couldn't I build myself a ball and spring type of AFPR kind of like the MBC? So it would restrict fuel flow up until the tension on the spring is met, but the spring tension could be controlled via a knob?
Also would I be able to run it in conjunction with the stock fpr?
