Driftmotion 2800lb PP and stock disc whats it like?
BigSupe
97
England
I need an upgraded clutch for my 1jz gt3076R build but I'm trying to keep it as driveable as possible as it's a daily driver
Anyone else using this setup with 400-430hp?
I got the stage 3, which has the 6 puck clutch.
I have no issues, but it can be a bit harsh, but it comes with the territory...
No chatter, and it does take some time to get used to it...
bigaaron
4,692
Pomona, CA
www.driftmotion.com
430whp would be pushing the limits, I would not recommend the stage 2 for that.
The stage 3 is totally daily driveable, it's not harsh at all. We just finished aother 1jz swap last week and it had the stage 3 clutch, very nice to drive.
I don't think it's harsh at all, but then again, I'm not a girlie man................:biglaugh:
I like the feel of it seriously, but it's the only clutch I've ever had so I have nothing to compare it too. It holds great and I've put over 500rwhp through it.
supra1642
113
Michigan
don't want to jack the thread but would the clutch be fine with a lightened flywheel and pushing 400hp max? mine is a daily and i want 400hp and have been looking at the stage 2 from driftmotion and just wondering if it will hold well.
again sorry for jacking the thread.
should hold fine at that power level...
personally, I used the stock flywheel as it's easier to DD the car with the heavier flywheel (and the same goes for drag racing it :evil2: )
supra1642
113
Michigan
why is that, will the lightened flywheel make the car chatter at take off like a 6 puck clutch? or is it because it'll last longer?
rakkasan
Currahee!!
Fort Campbell, KY
Poodles;1011441 said:
easier to stall because it's light, harsh clutches have a tendancy to weld themselves to lightweight flywheels...
I have to disagree, I have a lightened flywheel, and I love the combination. Great set up, IMO
it's fact, it's why they use heavy flywheels in the first place, it's easier to get moving with a heavier flywheel (more torque)
bigaaron
4,692
Pomona, CA
www.driftmotion.com
Our lightweight flywheel friction surface is hardened, and it is twice as thick as the lesser quality units you are thinking of. And you will have no problems with it wanting to stall, the pressure plate is so heavy on a r154 clutch that the flywheel could be 2 pounds and still be easy to drive.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
Have you ever driven a 1jz car with a lightweight flywheel? I have yet to hear anyone say they had any problem driving a 1jz car with a lightweight flywheel. Maybe if you used it with an unsprung 4 puck disk or something, but a sprung 6 puck or stock disk works just fine.
eh, I got a 7M...
My old vehicle was an 82 toyota hilux, and people put heavier flywheels for more grunt...
Heavier flywheels are easier to slip and control IMHO, not to mention the higher torque transfer...
