Door lock stuck
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Oh, the dustcap on the cylinder? Well, they are replacable. I'd try using a jewler's screwdriver to reach in on the side opposite the hinge and pry it open. It the little door bent?
I'd pull off the door panel, take the lock cylinder to a locksmith and have the dustcap & door replaced.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
That's wierd. That flapper door will not pass go?
Something fell in it's way... That's really odd, because there's nothing in that area that can block it.
Take it apart. That's the only way.
billspreston01
555
North Carolina
locks are VERY easy to rebuild as long as you don't mix up the tumblers. mine were all sticking and I pulled them apart for a build and lube. For the door, all you're gonna need to do is take the little silver cover off (2 small tabs) and then take the plastic glow ring and the small silver plate off, there's you're "trap door" or "flapper door" or whatever the hell you wanna call it. Small spring inside to keep it closed. make sure everything is good, maybe sand her a lil bit (just to clean it up) check and make sure the spring is good (I use pliers and bend the tabs out a bit so it'll stay closed) then put it back all together, and throw some lube in there too, I think there might be a special kind to use, mine was a thick white goo (hahaha). When you put the flat silver plate back on with the rectangle hole in it, be VERY CAREFUL, it will go on 2 ways, if you put it on wrong you'll have to angle the key to get it in, and it can be a major PITA.
oh, you probably bent the damn door, or it came out of the "hinges"...or some ass hole jabbed something in there
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
i just let them sit in hot oil and let them boil for abit
pull em out bango works like charm 2 cyc oil is the best
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
MDCmotorsports said:
My drivers door lock "trap door" (The little part that is spring loaded to keep crap out) is stuck. I can't get a key in and I've tried spraying some WD40 in there.
Any ideas?
Have you tried the B.F.H. yet?
Justin
Speakers?
Spokane, Wa
that happened to mine a while back... just pull it out and disassemble, then reassemble, it'll take care of it :)
