Dok's E85 powered 2jzge-T build
dok33
My fuel pump precedes me
Apr 16, 2005
934
Austin, TX
suprahero;1215887 said:
I didn't know it was eighty dollars either. If it is, then I probably won't pay that. I'm not paying eighty dollars to race, tear my car up, and then have to pay three hundred or more to get it home. I thought it would be like twenty dollars. It's only fifteen here to race all day.
Yup, from: http://www.6speedonline.com/forums/996-turbo-gt2/151649-tx2k9-official-information-thread.html
"Cost: spectators will pay $20 to LMP on Saturday. Racers will be able to purchase a "2-day tech card" on Friday (NON-REFUNDABLE if you break on Friday night) for $80 (in addition to the $15 cost to enter on dyno day). If a racer only wants to run on Saturday, the tech cards will be the same price as last year, $45 (in addition to the $20 cost to enter)."
ihiryu
209
TX
Hey josh, how much that driveshaft cost you? have you gotten it in? I hear solid driveshafts like that make a lot of noise.
dok33
Apr 16, 2005
934
Austin, TX
:icon_razz You Jay Blue guys are so full of yourselves...
As my GF says, spent some time with my other girl last night (the redhead :naughty:). Got the driveshaft installed and Jon gave me a hand with the Walbro (actually he pretty much put it in lol) so I now have loud ass fuel pumps at both ends of my car :biglaugh:
The Shaftmasters driveshaft went in nice and easy (that's what she said) and completely got rid of my 45-60mph vibration I had before! Tried cranking the boost some more too, but I'm hitting fuel cut above 15psi with the T70 on the Lex/SAFC combo :( Have to figure out a way around that I guess, either that or spend some time on the street corner to pay for that AEM :1zhelp:
Still trying to track down the low rpm vibration I've got, definitely motor related and is worst between 1000 and 1500 rpms. Any ideas?
dok33;1219148 Tried cranking the boost some more too said:
What is your fuel pressure set at? I was hitting fuel cut on the dyno and we raised my fuel pressure up about five psi and I never hit it again. I'm not saying it will work with yours, but it did wit mine.
I can't help you with the low rpm vibration, but I think Poodles could if he wanted too.
Poodles;1219584 said:
Toyota in their infinite wisdom used a two piece for a reason. It would have been far cheaper to use a one piece (half as many U-joints, no center bearing), so I think I'll stand behind the engineers on this one...
dok33
Apr 16, 2005
934
Austin, TX
Vibration happens in neutral too so that eliminates the D-shaft.
Pic of ME and the GF :sarcasm:
That's all you're gettin:biglaugh:
Fuel Pressure is at 45psi, guess I could try bumpin it a lil more, but it's already pretty high..
Cute couple.
Yeah 45psi is high enough I guess. Mine is lower than that by at least ten pounds I think.
dok33
Apr 16, 2005
934
Austin, TX
Got my 880cc injectors and started tearin' into her today to put 'em in. Figured out I can double up the grommets on the manifold side but I'm still lookin for an o-ring that'll work in the rail. Off to NAPA tomorrow to get some more grommets and hopefully dig through their o-ring bin...
Also pulled the plugs to swap 'em while I got all the junk off and did a comp test. Looking good, 155-160psi across all cyls, wohoo! Time for more boost :)
Bought some of Scott's remaining Supra parts today too :naughty:
2.7 60' time be damned!! Probably time to reinforce my subframe and pick up a spare diff lol
Good looking set of slicks Dok. I try to keep a spare rearend laying around but don't tell my wife............:naughty:
