does the CEL flash for knock?
suprakidd
313
Glendale, Arizona, United States
my question is does the CEL flash if the knock sensors detect detonation? ive searched but no dice. i know its a pretty easy question but i cant find a definite yes or no.
also say is does flash, does it trigger the CEL with grnd or pos signal? thanks for any info :1zhelp:
stew_7mgte
73
Fontana, CA
I dont know the specs but if the ecu detects multiple hits from the knock sensor in a set amount of time it will trigger a cel. The cps will be your missfire indicator.
If you have a problem with the knock sensor circuit then it will flash past like 3k or something.
Backlash2032
1,823
Nebraska
When I had a code 51 it just had the CEL on solid. Not over 3k, not flashing. Also had very little power.. Easily slower than a 7M-GE lol
Oct 11, 2005
3,822
27
Thousand Oaks, CA
You mean code 52, not 51. There are multiple causes for setting code 52, and they set differently. However, the effect is the same, you get the full maximum allowed knock retard hit to timing. Its a 2d map, so the actual pulled timing depends on load and rpm, but it can be as large as 15 degrees.
