Does anyone know where this brack mounts to?
Oppie1
I Love Money Pits
Sep 17, 2006
196
Albany, NY
www.ryanoppelt.com
I have this bracket, which I believe is for where some alternator wires connect to. I just can't figure out where the heck it goes in the car. Can anyone shed some light?
Thanks in advance...
OneJArpus
2,798
Alt for sure, not sure exactly where it would go in the bay. Just find a decent place to mount it when donig the alt wire
The 1jz certainly has one on the RH inner fender & it's where the alternator charge wire terminates with the wiring that runs across the hood slam panel to the battery & fuse box. (JDM RHD)
The ring terminals on the alt outlet cable & chassis loom bolt together using the lug in the covered section of that box, there should be a nut with it.
You can just make it out in this photo, it's beneath the hydrofan reservoir, above the RH headlight, red top to it with the thick blue cables coming out.
