Does anyone have any 1j soarer knowledge?
odomd
computer illiterate
Jan 11, 2006
130
nj
Has anyone done a soarer or chaser 1j swap into an ma70? I have found lots of great info/diagrams for the supra based 1j and how to tell them apart. But the wiring/plugs and colors are different from what I've seen. Does anyone know what the 2 plugs that come off the driverside,1 oval 3 wires blk, blk/rd and white and the other more round 7 wires where they should go? May be to the fuse block/ old alt wire . How about the other end of the harness. 4 plugs to the body harness?
I just wish I could give them a 1099 for all the money I've spent this year. That would help me out on my taxes................:biglaugh:
bigaaron
4,692
Pomona, CA
www.driftmotion.com
This thread is exactly like the calls I get (litterally) every other day from someone who wants to buy, or already bought, this "smokin deal" engine set and they are looking for parts. Without fail, it's a Soarer or a Chaser. Without fail, you will spend more money and a lot more time in the end then getting a Supra engine set or clip. There are vendors preying upon uninformed mk3 guys daily, selling them things they know will not work without additional parts they don't even have available. We know exactly what we are selling you, and we will not exaggerate or mislead you to make a sale.
Wiring a Soarer harness into a mk3? I could, but I still wouldn't want to. Every body connector on the inside and the outside of the firewall would need to be changed. The Soarer motor mounts will not work with the mk3. The Soarer clip/engine set always has an auto trans, and in the rare even it is a 5 speed (very rare), it will not work in your Supra because the shifter is extended back.
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
preach on aaron
i got my engine and the only thing i was missing was a fan i got the engine set with EVERYTHING and got a hydrofan setup seperately and BARELY broke 2K and i have everything i need. but mine came out of a JZA70
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
i got a soarer set
i got a 2j pan
using a haltech e11v2
have my r154 on it
using BIC mounts cuz im an 87
goin single turbo, the stock soarer feed and drain lines wont fit with the bic mounts
I bought mine from the Kings of 1jz swaps. Do I need to tell you who that might be? For those of you out there that's slow, it's www.driftmotion.com .............that is all.................:biglaugh:
bigaaron
4,692
Pomona, CA
www.driftmotion.com
Bigzavs said:
i got a soarer set
i got a 2j pan
have my r154 on it
But you are not like most people looking to put a 1jz in their car. You have the knowledge to make a standalone work in your car and make your own harness, you found a rear sump 2jz pan which is not that easy to get, and you already had the transmission. Plus you are going single, which is even more custom work and parts.
We did that one the 2jz with BIC mounts, it fit fine.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
The Reaper said:
preach on aaron
That's cool, but it was from a jza70 to begin with, which doesn't really apply to people who bought an engine set from a Soarer.
The Reaper
Jan 10, 2006
1,909
Florida
i know that was my point
buy the right engine from the get go and things are WAY easier
Ken
350
Houston, TX
Aaron's right. It's a huge PITA to source all the parts if you don't have a front clip for your specific chassis. Trust me, I know. And even when you have sourced all the parts to get the swap to run, it highly likely that you are missing misc brackets and parts to make it look OEM. That's where the zipties and double-sided tape come in.
But between the JZA70 and JZZ30, the longblocks are identical minus the cooling setup. I was using a soarer engine. Now I have all the little things to make my swap look factory, but that has taken 2 years to collect the parts from friends hooking me up.
The Reaper
Jan 10, 2006
1,909
Florida
thats why i got lucky and got the hook up from ITR for the hydrofans and my engine set came with ALOT of stuff
it will look factory enough for me
bigaaron
4,692
Pomona, CA
www.driftmotion.com
Sorry to sound preachy, that's really not my intent. I'm also not saying this to sell something, I'm trying to warn people so they don't get stuck with a bunch of money into something that will not work for them. Some of the people I talked to had to sell their origional engine set at a loss and then go out and find another one.
The Reaper
Jan 10, 2006
1,909
Florida
i knew a guy that did this
he originally had a soarer one the guy TOLD him was a JZA70 engine set but ended up being a soarer set and the guy bailed on him....he was selling it for cheap with a cut harness and i was thinking about it and almost did it but found out it was out of a soarer so i backed out at the last minute
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
acutally i lucked out big time on that, a local shop had one just sittin around, they didnt want it and i got it cheap
lucked out there again, found a guy that hooked me up on the bellhousing and flywheel for a real good price
the prob i was having was the rear drain couldnt come up high enough to bolt to the hole on the block
