Do People Have Map ecu cars that Run well?
blk91
78
ca
I have been considering running a Map ecu for about 3 years now but never got around to installing it. I just bought a new supra that has lexus and 550's on it and i was thinking of installing it but most of there research I have done shows it as having tunning issues. Like most things people post more when they have a negative then a positive. So if any one has a car with a map ecu that runs well or has any other good feed back I would like to hear it.
Kanan
wiseco7mgt
dirty mechanic
Aug 12, 2007
811
queensland
I own a map ecu and im waiting for a few additions before connect it up, but a friend had one and it worked great on a 7m, comes down to the tune at the end of the day.
blk91
78
ca
arod;1174492 said:
Agree
I have a friend that has a 94 supra with 2jzgte and map ecu, after tunning with an experienced car tuner worked great. He is now going map ecu 2 for timing control and other things.
Thanks for Responding My car has a S-AFC right now that seems to have no Tune other then some correction to idle
with 550' and lexus AFM Car made 337hp and 350trq at 14psi with the tranny slipping very bad... And the current out put is Unknown. I would really like to see 400hp
Mk3Les
Just my 2 cents worth, if your looking to get 400hp and above save yourself the headache and go to a standalone ecu. That way you can control ignition as well, I'm not saying you cant get 400hp with a piggy back it will just make it easy.
LilMissMkIII
That Aussie Chick
Aug 18, 2006
4,110
Aussie Land
I have a map ecu 2.
Is going great, except for a miss when backing off the accelerator at high speeds. We are 99.9% sure this is an issue with the coil packs, and not the map.
My tuner also managed to figure out the timing control for the 7M with it, so I'm pretty bloody happy :D
blk91
78
ca
In my experience In cars with stand alones they seem to lack some of the Drivablity that stock ecus have. My freinds supra was a development car for Aem... and was tuned by Aem and Never ran totally right. I mean the car ran fine but always did some funny things on desell that they could not fix, and from what I gather the Aem and the ignition dont seem to play well with one another. I use the car as a daily driver. And really want to set up a tune and forget about it. And I just have not seen that with stand alones. Also I already have the Map ecu and harness.
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
If you already have a SAFC installed, just get it tuned with that. I have been running the same setup for 2 years and my car runs great, and did 393rwhp at 18 psi. Either buy a wideband, and learn how to tune, or take it to a dyno for proper tuning. I was able to tune my own using a datalogger and a Innovative LC-1 wideband.
blk91
78
ca
What turbo were you running?
