do i dare use this?
Cyrus
229
Bay Area, CA
this is an exhaust manifold gasket from eristic. it was riveted together at one point, but one of the rivets fell out before i even opened the box. the gasket was able to pivot around and just didnt seem secure with the 1 remaining rivet, so i separated them. i am wondering if i can get away with using only one of the gaskets?
Cyrus
229
Bay Area, CA
Toyota wants $45 for the exh mani gasket. :( I paid $45 for the entire head gasket kit that this 2 piece gasket came from. Still, I am thinking about buying the Toyota gasket. Taking the hot side apart ain't fun, so I'd rather have the right thing on the first try. I kind of don't like this dual gasket design. Seems weird to me.
Cyrus
229
Bay Area, CA
i liked taking apart the cold side better. i didnt have to get under the car.
anyway, im leaning towards the toyota gasket. hopefully i wont have to take anything apart afterward! :p
bioskyline
1,236
powell river bc
most exaust gaskets are dual layer. this is casue the aluminum head and the cast manifold heat and expand at diff temps. this helps prevent exaust leaks. your call, but the toyota gasket is gonna be 2 layers rivited togther.
Cyrus
229
Bay Area, CA
hmm really? the one i pulled off when i tore down the motor is waaay thinner than this, and i cant discern multiple layers. additionally, it has holes where the rivets in this double gasket were, but the holes are empty.
here are pics of the old exhaust gasket:
bioskyline
1,236
powell river bc
its also been torqued and since squised. but the rings around the stud holes and the ports are what hold the 2 layers togther (bit better design than what you have
heres a new felpro i had on my desk, which you can see is 2 layers.
Cyrus
229
Bay Area, CA
awesome i was trying to find a photo of a felpro. looks pretty similar to this eristic gasket.
ok, ill give it a shot. copper spray both sides and then hang it on the studs. hopefully that will compensate for the missing rivets.
Nope, factory is much different (much like the EGR cooler gasket)
Felpro is not like factory, and it likes to leak.
Another MkIII
697
Chicago
Who makes the kit? Please tell me you didn't use the headgasket from it.
-AM3
Cyrus
229
Bay Area, CA
Eristic Gaskets makes the kit.
and no, i did not use the head gasket, nor the EGR cooler gasket, nor the throttle body gasket, nor the turbo oil return line at the block. used OEM toyota parts for those 4.
KickinAsphalt: interesting looking gasket. however, the price is pretty much the same as OEM, and when price isn't drastically cheaper for an aftermarket gasket, i'd almost always go OEM.
Another MkIII
697
Chicago
and no, i did not use the head gasket, nor the EGR cooler gasket. used OEM toyota parts for those 2.
Had me scared for a moment, lol. Good call.
-AM3
KicknAsphlt
Occasional Peruser
Not sure about the OEM Toyota exhaust gaskets, but most exhaust gaskets are made of a single or multi-layer perforated steel with a cardboard interior. With these types of gaskets, one usually needs to retorque multiple times after a few heat cycles to ensure a proper seal...on top of that, you run a high chance of burning the gasket out over time, especially if the bolts/nuts back out. Remflex gaskets are designed to not have to worry about any of that...they're made of a thick graphite material that crushes/compresses when you torque it down. They're especially helpful if you have a warped flange anywhere, which is why I bought them for my truck. But, since I've used them I've never had to retorque and haven't had to replace a gasket on a properly-installed application.
I know OEM Toyota is the way to go on a lot of things, but if there's a quality and proven aftermarket product that goes for the same price as OEM....guess which way I'm going. But that's just me. At least keep an open mind and check them out.
