diy ffim
mrsoup
19
LONDON
ok guys any body built there own ffim ??????????? i was thinking of using the standard one and cutting the cntr throttle body mount of and maybe welding that back onto the front , obviosly after cutting a hole in it and welding the old mounting position up ......
am i stupid crazy or just dum.
ps i can mig and tig weld ally no probs
yaitsme
Beach Bum
Mar 2, 2006
245
Cheatham County, TN
Sethron's stepped up in the world, too, since then ....
bowsercake
828
Irvine, Ca
that stock to ffim idea seems pretty interesting. I wonder how well it actually worked. However, it seems like it might not be that much of an improvement considering the work involved. It's probably just better to get a Ron R or something similar.
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
im gonna be making a sethronesque intake manifold. It is a very cheap method to clean up your engine bay although i wouldn't trust the setup for high hp applications due to the fact the stocker was designed for a side entrance.
CarlosPTR210
435
Calexico,CA
www.ptr.com.mx
Sorry for my grammar:biglaugh:
Ebay parts:
Upper manifuld:25dlls
3.5 Aluminum pipe 2 fts: 50Dll
Aluminium weld job 60dlls: (need break and vacum alimuminium connections)
Throtlebody : 20 Dlls
Toyota '88 4runer throtle cable: 20Dlls
Metal custom altenator bracket: 10 Dlls (need to fit to adjust)
And time to install:cry:
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
A nephew of mine works at a metal fabrication shop that builds custom parts for customers like aap, balanced performance, etc....
I just cut up thick paper into the shapes that I need. He takes them and cuts them on aluminum, ss, or whatever I need it in . Does all the welding and fabrication for me.
It is tig welded. I haven't tested it and will have it installed when it is warm again. I have a Q45 throttle on it now. The stock one was used just for mocking up.
I do have a few parts in the works. WIll be ready for sale sometimes next year. Intercooler block off plates, nightpager brake adapters (might have MK4 ones too), 3 inch throttle body in the stock location, and a few others...
Sar-Supra
Powertrippin´
Aug 28, 2006
72
Currently in NY
Ok, I was also thinking about making a FFIM on my own. Would someone be so kind and explain to me why one shouldn´t use the stock throttle body. I can´t see the reason why it wouldn´t work. Ron´s FFIM is great but the engine rebuild is going to consume just what I was planning to invest.
Any help would be appreciated.
Thanks,
Sar
