DIY $53.50 4" aluminum intake.
Tnice17
121
CT
Hey guys,
I recently fitted a HE351 holset to my 7mgte with a ct26-t3 custom flange and was in search of a intake that is clean, performs well and has that classic supra look. This should work for any single turbo set up!
I needed a 4" pipe at about a 45 degree angle and a 4" filter. My budget was about $100, until I found this! $53.50 shipped!
Had everything I needed. Ill let the pics do the talking from here. Please note that I am running a DET3 with the MAF-MAP conversion, I will weld 1 bung on the tube for the PCV system, but you gets get the idea.
The quality of everything is expected for $53.50 but will serve the purpose just fine! The filter has a velocity stack, stainless clamps, the couplings are not reinforced but that's ok with me. The filter is a bit massive but it works!
We need 1 more straight silicone coupling, marking a straight line with 2" tape is the perfect fit.
Test fit just as the pipe comes out of the box. Will need to cut to fit as expected.
Before!
After!
