Difference in Turbo kits 67 vs 72mm for 2jz
I was thinking about getting one of the turbo kits off of driftmotion and i was wondering how much of a lag differnece between these two turbo sizes. Im just throwing out there if theres not to much of a difference why not get the bigger one.
Not trying to say bigger is better just trying to reason.
toyotanos
What will we break today?
2,844
Coon Rapids, MN
You are going to want to give more information for prospective smart people to use. Tuning system (piggyback/standalone), manual/auto, headwork, built or stock, fuel used, what kind of racing you want to do, etc. Lots of info is a good thing for you and will get the closest results to what you may actually se :)
You also want to state your goals- that will help a lot.
IBoughtASupra
4,455
Queens, NY
What are your power goals?
A stock 2JZ will spool a 67MM quickly and with a QSV, full boost at 20 psi, would come in at somewhere at 3200RPM. I have seen it. :aigo:
-Streetable Car
- Stock fuel Systemo
- like to run stock ecu as long as possible. If not AEM Standalone
- stock engine
Put it on and wondering what hp would it make all stock. Standalone if ihave to.
67mm .58 a/r 72mm .58 divided
What is the aristo stock psi?
rakkasan
Currahee!!
Fort Campbell, KY
I run the 67mm with a the .68 A/R from Driftmotion, and I think it's freaking awesome. While I'm running high compression 1.5JZ and stand alone, different from you, it hits REALLY hard. It's a great street set up, I love it
IBoughtASupra
4,455
Queens, NY
zSP3CTERz;1799950 said:
How much they go for^
Link?
You can find the journal bearings new for 900 over at SPRacingOnline.com. Ball bearings will be more but the journal bearing turbos are great, they spool a lot quicker that other 67MM out there, well at least, the 67s I have seen.
gurley0916
Gurley=Last Name not girl
Mar 10, 2008
1,138
Columbus,OH
I had a stock aristo 2j on stock ecu with map ecu piggy back with a divided .70AR 67mm journal bearing and saw full boost (20psi) at 3700-3800rpm here is the dyno graph
Then I put in 264 cams, and went to a undivided .81AR ball bearing precision 67mm and I get full boost 4200 rpm, here is the dyno (currently looking for a divided housing and going standalone so with e85 so I plan to gain back atleast 500rpm of spool.)
Those are some good numbers, you give me hope with my setup. Orderd a boost controller and Wideband yesterday morning.
