didnt pass smog HELP!!!
eviltouge
25
Socal
i need :1zhelp: it didnt pass smog. they said its runnning too rich and i need to know how to tune this down.
so i need your info please!!!
eviltouge
25
Socal
jetjock said:
Sigh. Post the numbers. All of them. Also check for and post any codes.
okai here its is
and there is only one code its 51
jetjock
creepy-ass cracka
9,439
Yikes, 5% CO. The CO2 is dismal too. Rich is an understatement but there's something weird going on because the O2 indicates a lean mixture. I'm guessing your exhaust system has seen better days. It's for sure rich though, the high CO and low NOx prove it.
Congrats, you're deep into the Gross Polluter category. Your car is the reason smog laws exist. It also shows why the system as setup sucks because you've likely been driving it that way for a long time. If I may rant for a moment this is why MKIIIs are Test Only in California. Everyone has to deal with the Test Only hassle when too many fail because people who don't know what they're doing screw with or fail to maintain them properly. List your mods.
You're obviously not running in closed loop because if you were even with a dead cat emissions would be better. That said depending on how long you've been driving it you may need a new one even after the root cause is fixed. It's amazing you don't have any codes other than 51 but it isn't the cause of your richness. You should fix it though. Check the TRSM or search here for info.
Could be lots of things. Fuel pressure too high, timing wrong, dirty air filer, bad AFM, coolant sensor, O2 sensor, exhaust leak near the O2 sensor, on and on. Put a meter on Vf and check both the long term fuel trim and O2 sensor activity then go from there. If that's Greek to you take it to an emissions tech. The problem is so bad it shouldn't be very hard to find.
eviltouge
25
Socal
hey how bout the cps if that broken is it that the cause the engine to run rich and i have a dirty air filter that cuz of to run rich
8,897
The cps can cause it to run out of time, but not necessarily rich. If you had engine speed reading faster than it really is, you would be rich. But there isn't a way to create that condition.
High for oxygen and carbon monoxide isn't normal. JJ is right, when a competent tech lays eyes and diagnostic equipment on it, he should see what is wrong.
eviltouge
25
Socal
well i guess he did see DMV for a $1000 or let the DMV fix it and smog for like $500.
what should i do? i dont want to do that is there something else wrong?
eviltouge
25
Socal
i have another question
you know how when the enigne is cold and you start it up and the idle should be around 1000 or more and when it warms up it should be 650
but mine did not do that it did a complete opposite
any helpful info
Oct 11, 2005
3,821
25
Thousand Oaks, CA
We cannot diagnose your car over the internet. Its not going to happen. You didn't even bother to respond to JJ's first two questions about Vf and O2 cross counts. So, take it to someone who knows what they are doing, you are not going to fix this by randomly listing every sensor in the car post by post.
jetjock
creepy-ass cracka
9,439
Ja. Resolving emissions issues requires a solid foundation of advanced automotive understanding plus lots of specialized knowledge. Reading comprehension and the ability to construct coherent sentences would seem to be prerequisites.
