so my car as you see in my recent threads was burning oil. it seems..from what I've watched..it does it sometimes on take off not very often, sometimes when I down shift like
going around a corner but when it really does it is on boost I would say 8psi or higher and when I let of the throttle after boost so vaccum is at like -24 then it also smokes but it's not like big clouds of smoke or a lot just enough you can see that it is burning oil
I did a compression test and all cylinders were within 10% I didn't do wet becuase it passed dry
now do you guys recomend trying anything else or does this sound like an exhaust seal on the turbo? it's still under warranty with driftmotion so I'd like to make sure it's the turbo before I send it back
