did a compression test this weekend
Rich
tunin' tha beast
Jun 2, 2007
319
the netherlands
tissimo;935755 said:
compression numbers give a good indication to the health of the engine (ring wise)
don't forget the valves play a big role in compression too ;)
89jdm7m;935811 said:
it's supposedly due to the reduced size of the combustion chambers in the 1jz head, opposed to the 2jz head
yes, i know that, but has anyone actualy measured this?
Andre
115
Netherlands
I did not measered this because i do not have a 2JZ head
To do this you wil need 2 stock head that has not be surfaced
BTW maybe your numbers are so hi because your head has been surfaced more then ones ????
BTW does camgears has influence on the compresion numbers ?
I wil do an compresion test to to see how healthy my engine is
And if the numbers are to low i wil raise the boost :icon_razz naah just kidding
Maybe i wil do an leakdown test
Rich
tunin' tha beast
Jun 2, 2007
319
the netherlands
Yes, that's the best way to compare heads; use stock ones.
As far as i could tell this was the first time the head was surfaced; no signs of milling.
Camgears don't influence compression numbers, leaking valves or leaking rings will.
Hope your compression numbers turn out good as well.
Andre
115
Netherlands
I thought iff your valves where open at the same time ( iff you are using adjustable cam gears) the numbers would be lower then when you set you camgears at zero
Somebody correct me if i wrong
WeDgE
Buh-bye 7M...
Jan 2, 2006
495
Alberta
At TDC, none of the valves should be open for the compression stroke.
Rich
tunin' tha beast
Jun 2, 2007
319
the netherlands
you're confusing the overlap during the intake/outlet stroke with the compression/combustion stroke; then valves are all shut like wedge says
viperkillertt;944397 said:
Very nice!
tissimo
Stock is boring :(
Melbourne, FL
with more overlap the valves are open longer while the piston rises, force the air out through the valves, less air in the cyl = less pressure at TDC.
Andre
115
Netherlands
Thanks for the info
BTW i want to do an compresion test
But check my settings (cam gears)
Should i leave it like this ? are just set them at zero
tissimo
Stock is boring :(
Melbourne, FL
if thats how you run your car around town, do it. Dont stress over the finaly numbers too much (unless they're abnormally low for whatever reason) but more of they're all equal.
IIRC it looks like you advanced the exhaust cam quiet a bit and retarded the intake cam? i might be backwards though, but if you did that, you have decreased the overlap and you may have higher numbers then you would if you had them zeroed
Rich
tunin' tha beast
Jun 2, 2007
319
the netherlands
yep, that's correct
he got this engine this way from a mkiii straight from japan, it has been tuned over there and he didn't touch the cam gears
