compresion was at like 60 in cylinder two and three was low too. i put a drop of oil in cylinder two and it bumped the comression up for a bit. im thinkin worn rings? valve seals maybe.?
it's not the pulley do a leak down test andjoeyd23 said:when i got the car it had one of those undredrive crank pullys off ebay that claims better performance. the problem with these is that the stock pully is also the harmonic balancer for the crank but the ebay junk is not (but dood it gives u 5 hoarspower!).SOOOO.. im pretty sure my unbalanced crank was to blaim for this whole dilema.
