Cylinder Head Cooling Modifications.
Some of the German Supra guys have done it (120+ MPH sustained is the norm on the highways there), and it seemed to work better...
Are you using a standalone though? The stock ECU is tuned for the EGR, so it runs a bit hotter cruising without it (I'll have to search for the thread, but it's around here somewhere)
7MGTEsup
Formerly 'Down but not out'
Jun 14, 2005
614
England
The hole you drilled looks to be very close if not overlapping with the edge of the gasket.
There's a coolant passage on the head side of the EGR cooler...the big heater bypass/feed fitting is directly above it. Without the EGR cooler there and the exhaust port sealed off, I can see coolant temps being a bit lower. Looking at EGT though, having an EGR lowers exhaust gas temps. I had a 50-100 deg C drop in EGT (depending on throttle setting) when I re-installed the EGR to pass emissions.
I've seen guys drill that hole to create a coolant passage at the rear of the head...it's of limited value IMO.
Doward
4,245
Alachua, FL
Yeah, I was looking over the head's coolant flow in relation to the block, and found the block has the passage crossover to the head, but the head has no receptacle.
Standalone here - The stock USDM ecu is programmed for EGR, but I won't be doing the same in my own tune.
Down, the hole looks very close to the gasket, but it does not overlap when the gasket is lined up correctly. Look at the bottom - it's hard to hold a gasket and head together, with no movement, while snapping a picture ;)
Poodles, any more information on the german guys?
Doward
4,245
Alachua, FL
Ah, SF. God, I opened the link in another tab, took a deep breath, and am wondering if I even want to waste my time.
eh, what the hell.
Ok, to hell with that thread. 15 posts, and it becomes a bitch fest.
I think he drilled the holes too big though - look directly above that, you have the main water port coming out of the head, back around the block, to the water pump. Too big of holes right under there will reduce the flow elsewhere in the head. I was mainly looking to even out the flow of coolant around the cylinders, and through the head.
iheartmx83
23
CA
in my other cressida, i drilled that hole, cordless hand drill ftw LOL. put arp head studs(90ft lbs), and a 2mm MHG (overkill i know, but the head was machined so boohoo).
the drill bit walked, but eh. good enough. hte hole i drilled is actually slightly bigger then the other coolant passage holes.
lookind down the heater tube thing on the back of the head
meh..been 12,xxx mile... i drive it hard, shit still runs :drink1:
