Curise Control Delay
jetjock
creepy-ass cracka
9,439
Could be several things. The "see-saw" valve in actuator is dirty or the spring bad, the speed sensor in the speedometer is bad or being effected by something else in the speedo or the speedo cable, lost motion in the linkage, bad vacuum pump, ect. Run the CC diagnostics. Also check for engine codes.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
I have the same problem and had it on my old honda too.
I hit the set button, then the accell button until i feel the gas pedal start to rise. then I release it and it stays right there.
Mine got a little better when i tightened the cable almost as much as possible, but it still delays 3-4 mph.
Jayhall
WHIP THE PISS OUT OF THEM
May 7, 2005
1,167
Surrey BC
i thought all vehicles did that? thats why i always set it +5mph and let it fall to where it wants to
mine gets faster over time (we're talking over hours though, as on a roadtrip)
I went through and took out a LOT of slack in all the linkages though...
