I'm thinking I might do something interesting with my cargo cover (or luggage, trunk, or "boot" cover, whatever you wanna call it), but it involves taking it apart. Anyone ever attempt to do this?
Just curious...
Just curious...
yhatzee89;1946097 said:Are you thinking of having some new vinyl put in it?
suprasick;1946110 said:Yes I have. It's not bad at all! From memory there is a built in spring coil, a metal key the goes into the coil, and the end caps act as a stopper for the key so the spring gets tension as you pull the cover out. A quick tip would be to pull the key so its barely touching the spring so you can wind it a few times without hitting the end cap to give it tension. (it'll make sense with you have it apart)
yhatzee89;1946137 said:I like the top one, but that's gonna reflect a lot on the back window
Drake69;1946179 said:Almost like it could have been a dealership option at one point for all anyone knew.
