7mgte gods:
I need a hand with this issue, I have 87 7mgte supra, current mods are:
Free flow 2.5 exhust
k&n filter
FMIC
Manual boost controler set at 12-13lbs.
boost gauge.
8.5mm sparkplugs cables.
all the piping is new(I mean turbo pipping)
No leaks(cheak 4 times)
I have a code 41 and 51, and find out doing test with toyota manuals, bad TPS I tried to set it up but it is the sensor (alredy order one).
But the real Q is why when I tried to go to 13lbs the boost rapidly go back to 7lbs?I remove the turbo smart tee (MBC) and happend the same with stock boost, only this time go lower than 7lbs.
I use to have a greddy profec A ( sucks) but it is no longer working (God knows why), what puzzles me more is that it is not always like this, some times work great (steady at 10lbs or 13lbs) and most of the times go al the way to 13lbs. and then return to 7 (or less ).
I apologize my English is not that good.
Can you point me in the right direction to spotthe problem?
I was thinking to change the wastegate toonethat isin DM at 11psi, guessing that wastegate is the problem.
THank you guys for your time and help, again sorry for any misspelling.
Best regards
Ari.:icon_bigg
k&n filter
FMIC
boost gauge.
Best regards
Ari.:icon_bigg
