ct12a question
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
MDCmotorsports said:
IIRC 12A's have ceramic wheels in them. Any thing over 14psi goes kaboom.
I think we should clarify that....it will go Kaboom after repeated high boost levels and a beating down on it over and over...
A lot of people have the perception that as soon as you go over 14 psi..the turbo will blow.. lol. ( Im not talking about you MDC, just the newbies..)
OneJoeZee
Retired Post Whore
aboard the Argama
They will eventually die anyway. People have ran 18+psi on them for extended periods with no issues and others have had them die in a short time at stock boost...
for example, the turbos i'm using now have seen over 20psi. they are still ok. The turbos that came on this engine I'm using now were blown already and it was stock...
MDCmotorsports
Indy 500
www.MDCmotorsports.com
honestabe said:
From what I've heard and read, the stock twin's are only good up to about 350 rwhp. After that the compressor wheels crack from the heat. A good remedy for this is to upgrade to steel compressor wheels.
Adam
Steel turbine wheels good sir, not compressor wheels.
OneJoeZee
Retired Post Whore
aboard the Argama
Evilempire1.3JZ-GTE said:
no steel wheels lag you might as well go get a single and upgrade it.
Have you experienced a 1J with steel turbine blades to know if the lag increase is significant to make them worth it or not? My guess is no.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
honestabe said:
From what I've heard and read, the stock twin's are only good up to about 350 rwhp. After that the turbine wheels crack from the heat. A good remedy for this is to upgrade to steel turbine wheels.
Adam
With a more open y-pipe, and bigger cams, you may find otherwise :)
There's a guy on SF running 370hp, and over 400ft/lb of torque on stock twins with what I rmember being not much more then a set of cams.
I will agree with you, heat kills these things. You want to get rid of heat, you get a more free flowing exhaust to dissapate, the heat, and larger cams, allowing the engine to consume the same amount of air at a lower pressure ratio, allowing the turbos to operate in a more efficient range.
