CT exhaust housing stuck
sagillman
17
freeport, fl
I'm in the process of tearing down my ct26 for rebuilding and I can't get the dang turbine housing off I have tried every suggestion in MDCmotorsports rebuild thread for hours and no dice. anyone know another trick? :1zhelp:
Devin LeBlanc
1,830
Las Vegas NV.
Had the same problem, Acetylene torch did the trick.. Or just spray it with PB Blaster and let it sit for a while then use a flat punch and hammer to spread it apart.. What I did on another turbo as well..
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Devin LeBlanc;1642237 said:
...... Or just spray it with PB Blaster and let it sit for a while then use a flat punch and hammer to spread it apart.. What I did on another turbo as well..
Doing this, you run the risk of breaking the bearing housing or exhaust housing "lips."
