I have a 90 turbo. It used to be an auto but now is a 5 speed. Just bought it. Would anyone know what I should look for to get my cruise working?? Light comes on but nothing else works on it.
Davismj711;1408219 said:On the 3 wire round plug described in the write up you need to run the white and black wires through the firewall and connect to the clutch pedal switch.
The above write up simply wires them together to bypass the neutral start switch system.
The cruise needs to know that the car is NOT in neutral in order for it to function. Reason they need wired to the switch on the clutch pedal ^^
Davismj711;1408211 said:The TSRM will in no way help you with that.
Davismj711;1408219 said:On the 3 wire round plug described in the write up you need to run the white and blue wires through the firewall and connect to the clutch pedal switch.
IJ.;1408226 said:ummm errr you sure on that?
Clutch switch is to disconnect while engaged so the engine doesn't free rev trying to match road speed with the clutch pressed in.
Davismj711;1408510 said:Ian
If the Cruise recieves a neutral signal it will not engage. When this swap is done many simply bypass the neutral start switch. This tells the cruise that the car is in neutral,and always in neutral.
By running said wires to the clutch pedal switch you are only making that connection when the clutch is depressed. It would and does in fact cancel the cruise if you push the clutch in. It also as I said "fools" the computer into beleiving that the auto tranny is in gear.
In esence the neutral start switch normally found on the automatic is being replaced by the switch on the clutch pedal. I know this works as I have done the mod myself. Done any other way, and you dont have cruise, or, your car starts in gear.
Below is a link to a good write up.
http://www.supraforums.com/forum/showthread.php?t=164464
If you have anymore questions feel free to ask. I did the swap last year and did the wiring correctly to have cruise control.
