Crooked Hatch
BlkSupra87
Addicted to SupraMania!!
Jun 23, 2006
187
Los Angeles, CA
I hope this is the right place to post...
I have a problem with my hatch. It shakes while driving. It doesnt open smoothly... I have to push it open. and close up you can see that it doesnt sit flush with the opening.
What tips can i got to fix it. hardware, etc... Would be appreciated.:1zhelp:
blackout_89t
King of the roll
Apr 25, 2005
488
Toronto
There are two hinges that hold the hatch to the body on the underside of the top of the glass. Each hinge has two bolts (10mm, I think).
They may be loose like already stated, so check those.
DyslexicSquirrel
Busy Member
Mar 9, 2006
239
San Marcos, TX
OK, I hate to hijack but my car has the same damn problem. The hatch rests ALL the way to the left and there is a huge gap on the right. The previous owner wrecked it and that was the outcome. would the hatch hinges be bent or would the whole damn hatch frame off been knocked out of whack?
SupraDerk
The Backseat Flyer
Sep 17, 2005
546
Tallahassee
If it was in a wreck then the chassis might be bent. You might be able to adjust it by lowering one side or raising the other, which ever works out (if you can) to kind of make up for the bend.
blackout_89t
King of the roll
Apr 25, 2005
488
Toronto
There are also rubber stoppers on each side of the hatch. They could be missing causing the hatch to sit lower than it should be?
BlkSupra87
Jun 23, 2006
187
Los Angeles, CA
Ok guys... I love these ideas, but can you post pics for me so I know how to do this....
if you dont mind to. I would love to learn how to do most of this stuff.
:icon_surp
BlkSupra87
Jun 23, 2006
187
Los Angeles, CA
I looked at the rubber stoppers... one is bigger than the other.... How big is it supposed to be? I can cut the longer one....??? any suggestions? before I do cut it.
