from my experience, (i actually have a cressida 7m in my supra due to a rod flying out of my oil pan last year) they are pretty much the same. oil pan is different cause a cressida is a front wheel drive, I guess the cross member. and becuase the oil pan is different, if i can remember, i think i had to change my oil pump as well. it was either cause of the way it its with the oipl pan being different or cause the rod kinked the brass oil lines on the pick up. that i am not 100 percent sure on. and intake is different. when the motor blew on mine, and when i got the cressida, the intake was differnent. so i had to buy a new gasket set to switch mine back over. there wasn;t enough vacume hoses on the throtle body. but from my knowledge, the head is the same, both 24 valve, and both internal are the same, both 3.0 with a compression ratio of 9.1:1. hope this helps.
