iam wanting to get a lightweight crankshaft for my n/a while iam doing the rebuild, but i havent been able to find any does anyone know of anyone who makes them?
Doward;887819 said:How high do you plan to rev it?
the 6M crank is lighter (early 7Ms) while the 7M crank is smoother (I would lighten this, and use it for an 8k+ rpm N/A)
AJ'S 88NA;887832 said:Have it flycut, my stroker crank is 5lbs lighter than stock. It would have to be hardened again.
Don't know of any around here, ask around there should be some around Chattanooga. A2Z in Hixson does some rebuilding, maybe they would know. They have a Dyno:naughty:gnarkill87;887938 said:know any good machine shops that would do it?
gnarkill87;887935 said:does the 6m crank change the stroke?
MassSupra89;888518 said:Nope the 6M crank is what was used in 86.5-89
gnarkill87;888650 said:yeah no more vocab! lol my problem is iam rebuilding my motor and i need my crank to be reground because i spun a berring. so would it be cheaper to buy a new crank then you get crank pistons and rods and everything balanced?
labrat469;888687 said:It might be cheaper to buy a new crank. The previous owner of my Supra spun bearing number 5 on the main and ate the crank up. Strangely enough that was the same problem my second motor.
Autozone has a reman crank kit from around 350.
Advanced Auto has a reman kit from around 300.
Both should come with matching bearings.
Yes I would take it all in and get it all balanced. And talk to the machinist about possibly lightening it all. Tell him what your plans are and see what he suggests.
AJ'S 88NA;888999 said:You may not need a new crank, you have to have it checked to see if it can be reground. Then the machinist will mic it and tell you what size bearings you will need. It's best if you let them mic it and set the crank and pistons so they can size the bearings. Another thing is you will have to see if and how much the block has to be bored and get the pistons and rings to match. Block should be line bored, crank, pistons, along with flywheel should all be balanced together. I've used the stock flywheel and just had it turned.
IJ.;888703 said:
