crank pully
S
Supracharged88
Guest
i couldnt find this anywhere in the site but does anyone happen to know the torque specs for a 1jz CRANK PULLY BOLT thax.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
oh it says T=3300 (KG*CM) which is 243ft lb converted. the exact same as a 2jz :):) was wondering what are you using to take your crank pulley off? or what did you use
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
Taking off the crank pulley, do you have the motor in the car still? If so, put a breaker bar on the bolt, rest the handle on the ground, and crank the motor with the starter a few times. It'll break the bolt loose.
As for a special pulley removal tool:
I also cut a small metal plate, put two holes in the sides, with long bolts screwing into the pulley. I put a socket on the crank bolt, had the plate resting on it, and as I tightened the bolts in the plate, it would pull the pulley off.
JustinGotA1j
532
Chilliwack
My motor was in the car and I just got under it while it was on the hoist and used a big bastard of a screwdriver and pried it off nice and gentle. Came off pretty easy.
