crank bolt help needed
Status
Not open for further replies.
noredline
Yeah, I'd stands on that.
Sep 26, 2006
94
Chandler, AZ
I have searched and read every thread that was posted about the crank bolt and the bitch that it can be. I decided to thread some rope down the #1 plug hole to prevent the pulley from turning, however I can not get enough force to break that bolt loose, and I am a big guy. It was put on with air tools so I am curious if I just need alot more power. I am also using a 18 inch breaker bar, do I need a larger one? Also had tried bumping it with the starter before with no luck. Any help is appreciated.
87T 5sp
turbo4toy
208
Los Angeles
I think its torqued at something like 195ft/lbs. I had someone in the car holding the brakes with the car in gear and one hell of a breaker bar. You should be able to get it loose with a good impact wrench.
Suprawannabe
meh... im lazy
Oct 27, 2005
122
Denver, CO
GrimJack said:
I've never had the starter bump fail me. If that's not working for you, you're pretty much FUBAR, the starter puts out WAY more torque than an impact gun.
That what I did, one quick turn of the key (cps disconnected) and it broke loose. I was surprised how easy it worked.
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
yep, thats teh onyl way you can do it w/ the engien out of the car. w/ the head off.
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
I couldn't get a 550 ft/lb impact gun to take it off, even when it was torched!
I ended up having to wrap a chain around the engine stand, bolt it to 3-4 flywheel bolts (snapped about 2 trying this), put a large block of wood standing up under the crank shaft (i was putting so much torque on it, it wanted to bend down alot and i thought i was gonna bend or break the engine stand). I also ratchet-strapped it to a cherry picker for extra support, it was a huge bitch to take off!
Status
