couple of questions
mk3concepts
1j on the way!
Apr 2, 2006
268
Bay Area, Une Town
ok so im changing my sparkplugs, i remove then and i notice that the 5th and 6th spark plugs have oil all over it..even where it ignites..does that mean my piston rings are bad??
next question is..how do you know if your turbo seals are blown, shot, gone etc. ??????cause smoke comes out from my exhuast every now and then..like every few miles i drive.
thanks
-mark
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
thanks
-mark
Mark,
The oil may just be your valve seals are gone. If the oil is on the ceramic part, then ususally its oil leaking from the valve covers.
YOu will notice puffs of smoke as you boost or your turbo may smoke at idle if they are blown. usually bluish smoke.
mk3concepts
1j on the way!
Apr 2, 2006
268
Bay Area, Une Town
ic ic.. i just changed my valve cover gaskets..oh yah after driving for a bit then stopping at like a sign or light..bluish smoke comes out of my exhuast..so turbo seals are gone??
suprastanger507mgte
Hayward , Ca
Yup...its gone......time to stick that upgraded one in :)
suprastanger507mgte
Hayward , Ca
mk3concepts said:
it is the upgraded one that i put on..the 60-1 trim
Well, locally you will get raped. How dow I know??? Because I tried.
I think your best bet is MDC here on the froums. His pricing is real good.
Or you can also send it out to PT in LA who does a lot of Ct26 rebuilds. I think they charge like $325 for a rebuild since yours is already upgraded.
