Hey I am about to install my machined 2J cams in my 1J. Ran across a couple areas.
1) I thought I remembered which cam is which...unfortunately that fell apart LOL...what is the best way to tell the intake from the exhaust cam?
2) In the TSRM (2J) during install it speaks of installing the cams, then loosening certain caps and turning 90 and 120 degrees...should I be doing this? I assume yes right?
3)Bought 2J cam seals assuming they were interchangeable. I understand they are not..correct? Just bought a set of 1J seals anyways...
