Correctly controlling boost levels
Orion ZyGarian
Jeff Lange wannabe
Apr 2, 2005
1,490
Sarasota, FLorida
www.suprastore.com
This post is from Joe Perez in the MiataTurbo forums. He's a really cool guy and great at writing. I'm not going to take any credit for any of this or rewrite anything, it's beautifully done as is.
Joe Perez;574727 said:
This topic has been coming up every now and then. Specifically, a lot of folks seem to be having boost curves that look like this, and perceive it as justification for the fact that their manual boost controller just isn't cutting it, and they need to go out and spend money on a fancy electronic boost controller.
So, does that look familiar? If so, save your money. Fixing this problem is going to cost you about $3.
First, let's take a look at why this is happening. Here's a simplified diagram of your turbo system, where we have the turbocharger itself, then the intercooler, and then the throttle body.
Point "A" in this system is where a lot of folks have their boost controller connected. It's that nipple that came from the factory on the side of your compressor housing, probably with a hose already attached between it and the wastegate actuator.
Well, that's just stupid.
What's happening here is that your boost controller is in fact maintaining a constant level of boost, however it's doing it in the wrong place. Specifically, it's maintaining a constant level of boost at the compressor, but that's not what your engine is actually seeing.
Confused?
Yes, behold the simple drinking straw. Solver of great mysteries.
Here's a quick experiment. Stick a drinking straw into your pie-hole, and blow through it. Not too hard, very gently in fact. Very, very gently. This ain't Hustler's mom we're dealing with.
Feel the resistance that the straw is offering? No? Of course not. At the rate at which you are blowing into it, the straw is not much of a restriction at all.
Now, blow harder. And now you start to feel the straw fighting you.
A funny thing happens when we try to flow a gas through a restrictive orifice. The more we try to flow through the restriction, the more restrictive it becomes. In practical terms, at low rates of flow, we get very little pressure loss across the restriction. As flow increases, so does the pressure loss. And it's not linear, either. The magnitude of pressure drop increases almost exponentially with flow rate.
Now, it may not look like one, but your intercooler is a drinking straw. A large, heavy, aluminum, multi-faceted drinking straw. Or, at least, it exhibits a lot of the same characteristics as one. So, back to the diagram:
Say that we have our boost controller set such that we see a peak of 12 PSI in the intake manifold. At 4,000 RPM, we reach that point. We are, incidentally, flowing about 130 CFM through the intercooler (our engine has a 100% VE at all speeds) and we're loosing about 1 PSI across the intercooler. So while the pressure at point B is 12 PSI, the pressure at point A (which is what the boost controller is seeing) is actually 13 PSI.
Now, we increase the speed to 7,000 RPM. At this point, we're moving about 220 CFM, and yet, what's this? The pressure drop across the intercooler has increased to 3 PSI! We didn't even double the flow, and yet we tripled the drop. (Well, I'm ignoring the fact that these are relative, rather than absolute pressure values, but you get the idea.) So now, even though the MBC is faithfully holding 13 PSI at the compressor, we're only seeing 10 PSI at the manifold.
The solution here should be pretty obvious by now. Move the boost controller from point A to point B.
By doing this, we are now telling the boost controller, in essence, "Hey, I want you to do whatever it takes to maintain a constant pressure at point B in the system, and to hell with what's going on over at the compressor." And it will comply. (Boost controllers are pretty simple-minded like that. They don't question orders.) Specifically, it now does not matter what the drop across the intercooler is, at least insofar as your actual manifold pressure is concerned. As drop across the IC increases, the boost controller will cause the compressor pressure to increase accordingly. So by the time you get to 7,000 RPM and are experiencing 3 PSI of drop across the IC, the pressure at point A will be up to 15 PSI, and you'll still be getting your 12 PSI at the manifold.
And here's everything you need to make it happen:
Yup. One 1/8" NPT hose-barb fitting. About $3 at your local ACE Hardware store. Drill ye' olde hole into the pipe which leads up into your throttle body, install this fitting into it, and plumb a hose from there to your MBC. Using all-silicone tube? (fag.) Well, just drill a hole in the colid-side end tank of the IC itself. Anywhere is fine so long as it's after the IC core, and before the throttle body.
You'll probably have to turn the MBC down just a tad in order to achieve the same peak boost you had before, as it's no longer having to factor in even the smallest IC drop.
Vaya con Dios, friends. May your manifold pressure be stable.
Turbo Habanero
4,229
Tucson,AZ
That's awesome info
Thanks Orion.
I have a few questions.
So I'm still running a CT26 turbo and stock wastegate setup.
Currently setup up using the factory nipple on the turbo.
My question is
Since ill be running one line from the wastegate to the solenoid and the other to from solenoid to intercooler pipe closer to the throttle body, now what do I do with the open nipple on the turbo ?
Should I just put some vacuum line and block it off with a screw ?
IndigoMKII
2,181
Madison, Virginia
I'd like to add in to the people using the MAF system still. Even though you're maintaining the PSI in the intake manifold and on the boost gauge, you're pulling in more air to cover the loss of PSI in the IC/piping of your system. What I'm saying is, say at 3k rpm you're running RIGHT at the edge of fuel cut and you start to climb in the RPM's. As soon as the EBC or MBC tries to maintain your manifold pressure at the higher RPM's, BANG you'll hit fuel cut. Doing this will cause the turbo to work harder(More PSI) to cover the PSI lost. So as stated above, at 13 PSI at 7k your turbo will be at 15 PSI, which might be fuel cut for some of you.
Just my .02
